Can the "modified" column be displayed in the "yyyy-mm-dd hh:mm" format? I know a way to make new folders with various time formats, but couldn´t find a hint in the help file, if the display formats of the columns also could be customized.
The column uses the system date & time locale settings which can be modified via the Windows control panels.
Thank you! It looks, like the requested date/time format can be set.
