Is anyone else having problems reading posts
Windows 10 Home Insider preview Build 15019.rs_prerelease.17012-1513 IE 11.1000.15019
What I get is a sad face ERROR while trying to load
Something went wrong
Go Back Button Try Again Button
Was going to add screen shot but cannot find any option.
Viewing posts works ok for me in the current release version of IE, so unless they've broken something fundamental in the Insider build I'd say it's more likely to be related to your system. Try clearing your cache and forcing a page refresh.
You can add a screen shot to your post by dragging and dropping the image into the post editor.
Thanks for the reply
If I click the Try Again I get a blank screen
f I click the refresh page I can see the post.
If I'm the only one will put it down to using a Preview Build
