Can't Cylcle Through Images With The Stand Alone Viewer?
Recently I seemed to have lost all my settings in DO. I've pretty much got things back the way they were but I can no longer cycle through a folder of images with the stand alone viewer. I used to use my mouse wheel but that no longer works (I have the relevant box ticked in preferences). Not only that but if I right click on an image the "next image" and "previous image" are greyed out. When not in full screen view the buttons for next and previous images are also greyed out. Hotkeys (space/backspace) don't work either. Tried many folders full of images (and nothing but) but the result is the same.
I've spent a lot of time in preferences but can't see what the problem is.
Anyone got any ideas?
Turn on the Generate Next/Previous list automatically option.
That option was already turned on. I have cured the problem though. I opened a folder of images Edit>Select All then right click "View In Directory Opus" and I was able to cycle through the images. Now when I open a folder of images it cycles just fine. Seems it needed a jump start.
