Greetings Gurus, How do I navigate into the destination folder while changing it's vew mode at the same time. (I want to open in destination and change the view mode o thumbnails for example.
This works for the source.
go C:\Future\Dynamic\images
Set VIEW=Thumbnails
Go "C:\Future\Dynamic\images" OPENINDEST VIEW=Thumbnails
Or change OPENINDEST to OPENINDUAL if you want it to always use a dual display within the same window. That would also turn on the second file display if the current window only has one display, instead of using the destination which may be in another window.
