Changing Colors
Please post screenshots of the following:
[ul][li]What your status bar looks like.[/li]
[li]Preferences - Display - Images.[/li]
[li]Preferences - Display - Colors & Fonts, with Other Colors - Status Bar selected.[/li][/ul]
There you go!
Those are bigger so I put only thumbs with links to full sizes:
The 3rd pic is Display - Status Bar. Could you make one of Display - Colors & Fonts (with Other Colors - Status Bar selected) instead?
What colour are you aiming for the background to be, too?
BTW, You can attach screenshots to forum posts below the reply form. No need to use another image host, unless it's easier. (Use the "Post Reply" button to get to the full reply form; not the Quick Reply form that's below posts when you read them.)
Thanks for your help, leo!!!
I've attached the correct screenshot. This time using forum build-in feature :wink:
I've just realised what it is. Go to Preferences - Listers - Options and turn off Show glass status bar in Windows Vista.
If the status bar is glass then the background colour is always whatever colour the window glass is set to.
EXACTLY!!! :smiley:
Thank you for this tip, leo!
