Changing Default Printer
Ok, now I know this is kind of a different question but is it possible to make an Opus button that allows you to change the default printer?
I have two printers connected to my computer and constantly switch back and forth. If I had a button it would make it much easier.
Thanks.
It's possible. Take a look at the Print command in the Opus manual.
Customize / Commands / Tools / Change Default Printer
Thanks guys. Got it done now.
