Changing order of columns in details mode
I use a button to cycle through available list modes. It goes through: Large, Small, List, Icons, Details, Power, Thumbnails, Tiles.
I want to change it so that by default, the Details mode shows: Name, Size, Type, Shooting Time, Modified, etc. etc. The main point is I want Shooting Time fourth.
I've went into the Options and I can find Tools, Options, Lister Display Modes, and then Details mode, but it had no way to modify these settings. Can anyone point me in the right direction?
You can use a command like:
Set COLUMNS=name,size,type,datetaken,modified
That already should do it. But you can also specify positions of clumns, in case they are added on the fly
(note that the "3" might correctly insert the column in the fourth position, since the first one doesn´t count:
Set COLUMNS=datetaken(3)
Do you want Details and Power mode to have different columns?
If not, the best way to do this is using folder formats, so the columns are always there and in the order you want. i.e. Don't add/remove columns when you click the button; just have the columns there all the time.
(When you're not in Details or Power mode, the columns are irrelevant, so more or less the only time you might want to set columns when changing display modes is if you want different columns in the two modes.)
I have mine configured like this.
