Check avail space first
When i select 5 gig of files to copy to a 4gig encrypted container, it copies until it runs out and then akss me to skip and what not. If i select skip all, it will go file by file and attempt to copy it to the drive. If it reaches the max it will sip and go to the next. Why can DO simply not do a check first before coping.
For instance:
400mb free left
10gig of files still in queue to copy
  • 1 file is 500mb and the rest are all under 30mb.. for instance.
DO will attempt to copy the 500mb file and only skip it automatically once it copies 400mb and realizes that "opps... you are too big, let me try the next file in the list". While in the end, the result is the same, i waste a lot of time copying large files that I know will not fit.
