Checkbox mode
Is it possible to add the check-box mode to the default lister?
No way that I am aware of as checkbox mode is a dynamic function that resets (turns off) each time you change folders or open a lister.
On a related topic now that I'm getting used to it, I'm starting to like this checkbox mode. At first it seemed erratic and unpredictable and for some things it is. However checkbox mode seems to work very well when used with an external control code to open the checked items in another program. Which is something I do every day with DOpus.
John
