# CLI QUICKGO not working with network paths
**URL:** https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683
**Category:** Help & Support
**Created:** [March 16, 2012, 9:26am UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683 "2012-03-16T09:26:23Z")
**Posts on this page:** 6
**Page:** 1
<div class="post-metadata">
### Author: ![xbprm](https://resource.dopus.com/user_avatar/resource.dopus.com/xbprm/32/26109_2.png) [@xbprm](https://resource.dopus.com/u/xbprm)
#### Post date: [March 16, 2012, 9:26am UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/1 "2012-03-16T09:26:23Z")
</div>
Hello,
when opening a tab with Ctrl+T Dopus opens the "QuickGo" field. See below
![](https://resource.dopus.com/uploads/default/original/3X/8/5/853524bf27a80467d4ea5796fa8f620ae8b4446b.png)
I use this to quickly go to a new path/file in a new tab. This works fine with almost all paths except network paths. Pasting a destination which is a file on a local drive Dopus opens the folder and higlights the file. Perfect.
Doing the same with a network path, i.e. \server\path\file I get the following error
![](https://resource.dopus.com/uploads/default/original/3X/8/7/87a30b90f399051bfcaf24d18fd299af1b1bbece.png)
It reads: "[..] The folder name is invalid (267)[..]"
Regards
xbprm
### Author: ![Leo](https://resource.dopus.com/user_avatar/resource.dopus.com/leo/32/69732_2.png) [@Leo](https://resource.dopus.com/u/Leo)
#### Post date: [March 16, 2012, 9:35am UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/2 "2012-03-16T09:35:04Z")
</div>
Do you mean when the current folder is a network path, or when you paste a network path into the Go field?
Both seem to work okay here.
Does it happen if the command just runs "CLI QUICKGO" without the newtab stuff?
#### Post date: [March 16, 2012, 9:47am UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/3 "2012-03-16T09:47:42Z")
</div>
> [@leo](#):
Latter one does not work
> [@leo](#):
Have to check.
#### Post date: [March 16, 2012, 10:13am UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/4 "2012-03-16T10:13:21Z")
</div>
Is the path actually valid? Can you paste it into the location field in Opus? What about into Windows Explorer?
#### Post date: [March 19, 2012, 4:09pm UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/5 "2012-03-19T16:09:06Z")
</div>
> [@leo](#):
Yes.
> [@leo](#):
Same result, i.e. error.
> [@leo](#):
Opens the file normally.
#### Post date: [March 19, 2012, 4:27pm UTC](https://resource.dopus.com/t/cli-quickgo-not-working-with-network-paths/12683/6 "2012-03-19T16:27:42Z")
</div>
Sorry, I didn't realise that we were talking about file (not folder) paths until now when I re-read the thread.
I can reproduce the problem now.
