Hello,
can I use Go TABLOCK=lock
in the Command Line Interface Tool?
Many thanks and greetings
opusfreak
Hello,
opusfreak
It works fine here.
Since the CLI isn't tied to any lister or file display (unlike running commands by typing >
into the file display), it will run commands against the most recently active tab/window.
I suspect it is working, but not locking the tab you're looking at.
