I want to:
- collapse the group of the currently selected item;
- move the selection box to that group.
I got the first part working, but I could not locate a way to do the second. Is there any?
function OnClick(clickData)
if (clickData.func.sourcetab.selected.count >= 1) {
cmd.SetModifier("noprogress");
var current_group = clickData.func.sourcetab.selected(0).filegroup;
if (current_group.collapsed) {
var operation = "GROUPEXPAND";
} else {
var operation = "GROUPCOLLAPSE";
cmd.AddLine("Go " + operation + " \"" + current_group + "\"");
cmd.Run();
Jon
#2
We'll add a command for this in the next update.
The following line will be what you'll need to add:
cmd.AddLine("Select NOPATTERN GROUPNAME \"" + current_group + "\" SETFOCUS");
Tried that line, it is not working. It opens the Advanced Selection dialog instead.
//cmd.SetModifier("noprogress");
} else {
cmd.Run();
Jon
#4
Your script works ok here. Have you installed the 12.7.5 beta?
Yes, I am on 12.7.5 beta. The issues I mentioned in my other recent threads were fixed, so I guess a botched install isn't the case.
Leo
#6
We reproduced the problem and a fix for this is on the way.
