I'm making a dark theme and i want to set the background of a virtual location to black
And i want to make the text white.
When I go into options and check the Virtual folder options, the background changes black but the text does not change to white.
How do i change the text color on a virtual folder? I can't find a setting for it.
I STARTED WITH THIS:
I FOUND THIS OPTION BUT IT DOESN'T CHANGE THE FONT COLOR:
Thanks. It's turned black. . It's not the background I'm hoping to fix it's the font color.
I take it from previous posts that this is still not an option? The last post i found on it was from march.
Leo
May 30, 2022, 9:06pm
4
No change since March. We've only just found a way to modify those colors (by patching parts of the Windows API) and it's part of a very large piece of work that we're still finishing.
jimerb
May 30, 2022, 11:08pm
5
Ok thanks. I’ll keep an eye on the change logs.
