Color in FAYT mode
Preferences>>File Displays>>Find-As-You-Type>>DOS Command (the 2 color fields)
Please change colors (Text & Background) for DOS command and test. Colors are adopted from the Command. Bug?
(hi. i am trying to write concise, cute posts so not to waste whoseever time :stuck_out_tongue:)
Confirmed, I see the same thing.
I'll take a more detailed look later today or tomorrow.
Thanks for noticing it.
A fix for this should be in the next beta version (10.0.2.1; not sure when that will be since 10.0.2.0 just came out).
neat! thanks!!
:thumbsup:
