Hi,
is it possible to assign color tags to folders and files? Then I may be able to add a column with the tag?
Thanks
You can use labels for that:
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Labels1.htm
There is also a Label column if you want to see the label names (not just their colors and other effects).
Super!!! I knew DO had us covered
