Column For Used Keys
The hotkeys manager doesn't have a column for used/not used keys (checkbox). So we can't click the column to sort by that, showing us all our used keys in one click.
Sort By
It only shows the keys that are in use. There would be hundreds of blank entries if it showed every hotkey combination that wasn't in use. You can infer the ones not in use as they aren't in the list, and the list is sorted.
Ok. Also I found Ctrl 4 is showing in my tooltip for archive file, but it doesn't exist.
Ctrl 4
Ctrl 4 None
It's probably in the actual label of the button. The default toolbars add hotkeys by default but older versions had them included in the labels.
You're right, I didn't see that, thank you.
Label
