I consider the column header part of the lister, not part of the Pane Borders. However Dopus only seems to allow me to set the column header colors to the pane colors. Otherwise, on my system, the colors are black and white for the header text and background. Is there (or can there be) a way to set the column header colors independently? I would like the pane borders to be different colors for my normal lister (showing files/folders) and my folder tree.
We'll probably make the header and scrollbar colors independent in the future but there isn't a way to do it at the moment.
Thanks, Leo. I have survived this long with the current color scheme. Actually, version 12 gave me a couple of additional options in colors which I have already utilized. Obviously color details like this are fairly minor and I understand (and support) your priorities in this area.
