If I change "multipart_extensions" options (it's an example) then apply, columns headers are reduced (but not columns).
Thanks for the report!
Is that the only setting which causes it, or are there others?
There are others... I just test with some advanced options like desc_show_info, file_size_units, image_size_units... maybe others...
Thanks.
I think I've reproduced it, but it only seems to happen for me when I'm in a folder that has child folders but no files. Is it the same for you?
I can reproduce this if folder have folders, files, both or nothing.
