So you paste some files into some folders and somewhere in those folders there already is a file with the same name?
Is that correct? Are the folders you are pasting to DO file collections?
Yes,you are right.
Please download v0.3.8 and append " PT=WHENEXISTS=skip" to the command you are already using, the dialog should no longer appear.
Ok, thank you for your plug-in, you are great!
Updated to v0.3.8:
- new option "PT" to pass through parameters to internally used DO commands
Like in jhrs110s case, you can use "PT" to pass options like "WHENEXISTS=skip" through to the native DO commands.
Make sure this option always goes last in your command line, since it is a raw parameter.
The following command..
ClipboardEx PASTETOFOLDERS PT=WHENEXISTS=replace..will end up in severals calls to
Copy TO=<folder-chosen-by-clipboardex> WHENEXISTS=replace and thereby prevent the various "File already exists" dialogs.
What commands are used internally depends. At least for all the PASTETO/FROM.. options it is Copy right now. Things might change, if in doubt read the script or ask! o) The new "PT" option is a quick way to increase versatility without adding two dozens more switches to ClipboardEx itself. Thanks for your interest. o)
guess v0.8.3 = v.0.3.8
Keep up the good work!
Updated to v0.3.9:
- version string correction
@opw63
Thank you, it's even worse. The internal version was still at 0.3.7 which is now fixed as well. o)
Thanks! ![]()
Thank you for this great script, but I'm having trouble understanding how to make the PASTETOFOLDERS work.
This is what I've got:
ClipboardEx PASTETOFOLDERS "D:\Games\Farlands Awaits - Again\mods" ; "\\Rebekka-pc\c\Users\Rebekka\Documents\Curse\Minecraft\Instances\The Farlands Await (1)\mods" ; "C:\Users\c0d3n4m3\Documents\Curse\Minecraft\Instances\The Farlands Await (1)\mods"
And with that I just get an error "CLEAR.exists is null or not an object".
Basically, I don't know what I need to write for it to work. Please help a newb!
Thank you!
Please try this:
ClipboardEx PASTETOFOLDERS FOLDERS="D:\Games\Farlands Awaits - Again\mods;\\Rebekka-pc\c\Users\Rebekka\Documents\Curse\Minecraft\Instances\The Farlands Await (1)\mods;C:\Users\c0d3n4m3\Documents\Curse\Minecraft\Instances\The Farlands Await (1)\mods"
You are amazing, thank you so much. It works perfectly! I've been copy pasting into three tabs for months now, and this will save me loads of time!
Thank you, thank you and thank you again! Many times! Massive kudos to you!
Updated to v0.4:
- added COPYTIMESTAMPS (< all >,created,modified) feature (optional FROM/TO for cmdline usage)
- added PASTETIMESTAMPS (< all >,created,modified) feature (optional TO for cmdline usage)
- XLog updated to v0.45
As mentioned in the introduction, code for the new timestamp functionality is from @Leo.
I rewrote most of your ClipAttr script addin to be able to merge its functionality into this one and to additionally support (multiple) items passed on the command line. You can also choose whether to copy only creation or modified dates and finally there is a command to copy timestamps in one single line/call.
THANK YOU!! THANK YOU!! THANK YOU!!
I have a sporadic work-task of copying template files to 600+ file folders on a semi-annual basis and this has made the task go from being a major time-sink to a trivial affair.
THANK YOU!! (And all my affected users thank you too!!
How create empty folder with ClipboardEx PASTEEMPTY this button?
Hi dear tbone
your script is so useful for me, thank you so much.
I want to copy multiple Selected Folder name Then Use This Button ClipboardEx PASTEEMPTY for Creating empty folders but problem is the trailing "\" when I use This button Clipboard COPYNAMES=nopaths This button copy only the folder name, So how to add or copy the name with the trailing "\" so then I can create empty folder with ClipboardEx PASTEEMPTY this button?
Here is a three button button of copy timestamp, paste timestamp and current timestamp based on tbone's script, ClipboardEx, referred to in this thread.
Timestamps.dcf (1.2 KB)
For ClipboardEX PASTETOFOLDERS, two features do not work:
- Pasting text does nothing. Pasting a file does work
- PT=WHENEXISTS=replace gives an error message for replace
Win10
Opus 13.16.1
Please show the complete command line you are using, thanks.
The command
ClipboardEX PASTETOFOLDERSputs a file in the clipboard into the selected folder. -
The command
ClipboardEX PASTETOFOLDERS PT=WHENEXISTS=replacewhere the cilpboard contains a file gives this error
Under both 1 and 2, with text in the clipboard, no response at all happens and the selected folder remains unchanged.
In my situation, I copy files, select the folders to paste to, click the script button...
- when using just "ClipboardEX PASTETOFOLDERS" in the script, it works as you would expect. Files are copied without dialog if there are no existing files with those names, and with proper dialog when dupes do exist. Dupe files are copied, or not, based on the option selected.
- when using "ClipboardEX PASTETOFOLDERS PT=WHENEXISTS=replace" in the script (the only command in it) prompts the error that jinsight and I are both encountering.
