The closest you can get is to create a user-command that does what you want, giving it a short name, then run it from the FAYT field.
For example, with the user command in the screenshot below you can type ">ff www.example.com" into the file display* and it'll launch that URL in Firefox.
(*So long as it's not displaying a system folder like My Computer or Desktop.)
