GP SoftwareTwitter
Opus FAQsManualCommandsObjects
Command: Find ADVANCED -- does not work as expected
#1
Hello.
I have a button with one command (Find ADVANCED). It does not switch to Advanced mode if Find panel is already open in simple mode. Also if you open the Find panel in Simple mode, switch to another Utility panel (e.g. Sychronize panel), and then click the button, it opens find in Simple mode.
#3
I've found a partial workaround:
@ifset:UTILITY=Toggle
Set UTILITY=off
@if:common
Find ADVANCED
However if the Utility Panel is already open in any mode other than Find, it closes the Utility Panel, but DOES NOT open Find.
A workaround for this is to insert "Set UTILITY=Find", but I wouldn't expect this to be necessary:
Set UTILITY=off
@if:common
Set UTILITY=Find
Find ADVANCED
#7
Thanks, we'll fix this in the next update so that Find SIMPLE and Find ADVANCED work as expected when the panel is already open.
