Command to Move Tab to Vertical Dual (other side)
There is an option on the tab's context to [Move Tab to Right] but I don't see a command to do this in the reference manual. I want to create a keyboard shortcut that moves the current tab to the other side (left to right, or right to left). Is this not possible?
I think you want Go TABMOVE
Thanks, that worked.
