Bellow are some commands to make it easier to manage tags on media files.
I am sharing just the callback functions, as I put them in a script with many other commands that are not relevant here.
- List Tags
- Lists all unique tags for items in the current source directory.
function OnListTags(scriptCmdData) {
var tags = {};
for (var eSel = new Enumerator(scriptCmdData.func.sourcetab.all); !eSel.atEnd(); eSel.moveNext())
if (eSel.item().metadata.tags && eSel.item().metadata.tags.count != 0)
for (var iSel = new Enumerator(eSel.item().metadata.tags); !iSel.atEnd(); iSel.moveNext())
current_tag = iSel.item();
tags[current_tag] = current_tag;
var tag_list = "";
for (tag in tags) {
tag_list += tag + "; ";
DOpus.Output("----------- List Tags -----------")
DOpus.Output("Target: " + scriptCmdData.func.sourcetab.path);
DOpus.Output("Tags: " + tag_list);
DOpus.Output("---------------------------------");
- Enforce Standard Tag Names
- Find and replace with a dictionary;
- Dictionary hard-coded on the script;
- Selected files only;
- One-to-one and one-to-many;
function OnEnforceStandardTagNames(scriptCmdData) {
var dict = {
"1": "One",
"A B": {"A": "", "B": ""}
var Progress = scriptCmdData.Func.Command.Progress;
Progress.pause = true; // Allow pause button.
Progress.abort = true; // Allow abort button.
Progress.Init(scriptCmdData.func.sourcetab, "Enforce Standard Tag Names");
Progress.SetStatus("Enforcing standard tag names...");
Progress.SetFiles(scriptCmdData.func.sourcetab.selected.count);
DOpus.Delay(200);
Progress.Show();
var factory = DOpus.Create();
var tagCmd = factory.Command();
var eSel = new Enumerator(scriptCmdData.func.sourcetab.selected);
while (!eSel.atEnd()) {
// Handle progress flow control.
var abortState = Progress.GetAbortState();
if (abortState == "a")
break; // Aborted.
if (abortState == "p")
DOpus.Delay(500);
continue; // Paused; restart the loop to see if we are still paused.
var current_item = eSel.item();
// Handle progress display.
Progress.SetName(current_item.name);
Progress.SetType("file");
//DOpus.Output("[Tag Replacement] Target: " + current_item.RealPath + ";");
tagCmd.Clear();
tagCmd.ClearFiles();
tagCmd.AddFile(current_item);
var replaceOptions = "";
for (key in dict) {
if (current_tag == key) {
replaceOptions += "-" + key + ";";
logNote = "[Tag Replacement] Removed: " + key
if (dict[key] != "") {
if (typeof dict[key] == "string") {
replaceOptions += "+" + dict[key] + ";";
logNote += "; Added: " + dict[key];
} else if (typeof dict[key] == "object") {
for (nested_tag in dict[key]) {
replaceOptions += "+" + nested_tag + ";";
logNote += "; Added: " + nested_tag;
//DOpus.Output(logNote);
if (replaceOptions != "") {
var replaceCmd = "SetAttr META=\"tags:" + replaceOptions + "\"";
tagCmd.AddLine(replaceCmd);
tagCmd.Run();
} else {
//DOpus.Output("[Tag Replacement] Nothing to do for this target.");
// Update state data.
Progress.StepFiles(1);
DOpus.Delay(100);
eSel.moveNext();
The common use case is: list the unique tags in your items, create the dictionary with your preferred tags, then enforce their use.
To do (would be nice to have some day):
- Conditional or Implications: if tag X and tag Y are present, add or remove tag Z.
- Aliases: intercept search and add other relevant tags.
