Como criar um botão para uma opção do Meu de contexto. / How to create a context menu button
Does anyone know how to add this option to a shortcut button.
It serves to take a certain selection of files to the program that renames them in batch. However, after selecting, you need to click with the right button and sometimes this is a huge delay.
Having a shortcut button makes it much easier.
Alguém Sabe como adicionar essa opção em um botão de atalho.
Ele serve pra levar uma determinada seleção de arquivos para o programa que renomeia em lote. porém após selecionar precisa, clicar com o botão direito e as vezes isso tem um deley enorme.
tendo um botão de atalho fica bem mais fácil.
You'd need to check BRU's command line syntax. It's probably something like this:
"C:\Program Files\Bulk Rename Utility\BulkRenameUtility.exe" {allfilepath}
But wouldn't Opus' renaming functionality be the better choice anyway?
Hello friend, thank you very much. I'll check it out, to be honest I've only been using Opus for 3 days, I haven't seen the rename option yet.
I use bolk because I can rename several files, folders and make my own organization. if, by any chance, Opus does the same I will certainly use it only.
thanks again for the tip. i still need to learn how to turn this into a button but we have a start.
Your Stairway to Rename Heaven!
I would also add that you have a whole section of this forum dedicated to rename presets : Rename Presets - Directory Opus Resource Centre
I'll check it out right now. Thank you very much for your help.
I (still) can't find the option that I use the most in the Bulk Rename Utility, which is the option to insert certain words in the middle of file names. as you can see in this image.
I usually need to insert these words in the middle or at the beginning or even at the end of audio or video files. as I'm completely new to Opus. I couldn't find this option .
https://docs.dopus.com/doku.php?id=file_operations:renaming_files:advanced_rename:rename_actions:rename_macros
