is there a way to compare to images that will alike. There might be a subtle difference between size. Color wouldn't be a factor since their black-and-white. The basic size of the images also very close, dimension. The only difference would be the content of the image. The actual image is a document or a record. In most cases a file name does group the images. I don't know how I do it but it seems there is some kind of a difference when using duplicate MD 5 checksum. I have asked for help in the past regards to this. But I'm still out there trying to figure this one out.
I found something immediately on that way which I'm evaluating. Unfortunately you have by the product first to really test it, which I will be doing later today. If this works somewhat at all it will be a great help. If it does half of what it says it's unbelievable.
Bob
I use this program and it is free. Works pretty well and can create numerous profiles too. It is compatible with Win 7 64 bit OS. I hope you find this useful.
When comparing to images of text documents, building permits. Address information will be different but everything else is pretty much the same. I have any directories that hold over thousand images. I'm trying to find the images that are close to equal. Looking at a thousand images I might have 75 200 duplication's. Be able to find them automatically would be great. You still think MD 5 is my best bet.
Bob
