Composer column required
I need to have a "composer" column in DO Music metadata.
It is easy to do in Win10 File Explorer.
There seems to be no option to select one from the FIELDS in DO Preferences.
Is it somewhere else please?
TIA
I don't know of a way to do this at the moment. We recently added the ability to import any Explorer column into Opus via a few lines of script code, but it seems the Composer(s) column is special, due to returning multiple values separately instead of joined into a single value, unlike most columns in Explorer. I don't think we had seen that before, so we may need to make some changes to support it.
Thanks.
However, give that this is a fundamental field in any music database, when might this be expected in D/Opus?
I don't want have to to revert to File Explorer of use a 3rd party program like MP3Tag.
Ron
