Conditional lister placement
I configured DOpus to open new lister under mouse pointer. And this is quite fine for me, beside one case - I got some folder shortcuts pinned to taskbar (quick launch bar) and I'd love these to open centered on the screen. Is there any way I could acheive this w/o affecting other listers?
There are a couple of ways to do it.
The easiest way is to save a layout (Settings -> Lister Layouts) for each of the folders, with the window set as you want it in each case, then drag the layouts out of the Preferences window (Edit Layouts in the menu will take you there) and on to your quicklaunch bar.
Another way to do it, if you don't want to clutter up your layouts list, is to create buttons which run the "Go" command with appropriate arguments (new window, the path you want, the window size/position you want), and then (while in Customize mode) drag that button to your quicklaunch bar.
layout trick works and is almost perfect. One thing I miss - can I change the icon for it (i'd like 'regular' folder icon)?
Never mind. I use Free Launch Bar tool for my toolbars (much more customizable, incl. spacing between items) and it seems FBL supports custom icons. Thanks
