I would like to make some default configuration for the dopus viewer.
For example:
- Viewer size: Full screen or other
- Viewer screen: Number
- Meta info: yes or no
- Image info: yes or no
Thanks
For example:
Thanks
There are options in Preferences to control the window size and placement.
OK. I found them. I see there are not options for the meta and image info.
But that's ok for viewer size.
I don't find how to assign the screen. I have 3 screens and I want the viewer open always on a screen.
Thanks
It should remember the screen it was last on.
Turning on file info every time the viewer opens could be done via a script, but there isn’t a simple setting for it.
