Confirm and replace window set defaults
Hi, I was hoping someone knew how to change a behavior of the Confirm and replace window not to be confused with the Confirm and replace menu Image should help.
I was searching the forums and was not able to find an example of something like this.
I understand in German and other languages the text can get quite big if we have multiple boxes so we only have access to two as to minimized clutter of a full option box, I was hoping there was a way to set the default response, instead of holding X Y or Z it will just be what you set it to in config or possibly the last used? oh and if the addition of Delete Source File Conflicting/ Delete Both Conflicting Files. [Delete Source / Delete Both] is possible or is it a limitation on the application? the last one was curiosity, Thank you for taking your time to respond. Have a good day.
