Connect to normal and administrative shares like \\hostname\c$ with a credential from 1Password.
It will:
- open each share in a new tab
- reuse the credential across all connections
- assume a hostname is an administrative share and convert it from
hostnameto\\hostname\c$
The intended use case is calling it from Powershell, with a function that's loaded by your profile. This function could be called by a different function that looks up a users machine from their name.
Example profile function
function Enter-NetworkShare
[alias("ens")]
[CmdletBinding()]
param
[Parameter(Mandatory = $true, Position = 0, ValueFromPipeline = $true)]
[ValidateNotNullorEmpty()]
# designed for passing the entire share like `\\hostname\c$` but the Directory Opus script
# is fine with receiving just a hostname cause it'll wrap the rest around if it's missing
[string[]]$Shares
process {
$SharesList = @()
$Shares | Foreach-Object {
$_ -match "^(?:\\\\|)([-a-zA-Z0-9]+)(?:\\|$)" | Out-Null
$name = $Matches[1]
$Matches.Clear()
if( Test-Connection -Quiet -Count 1 -ComputerName $name )
$SharesList += $_
else
Write-Host "Couldn't reach $name" -ForegroundColor Red
$SharesString = $SharesList -join ','
& $directoryOpusRTPath /cmd:active ConnectToNetworkShares /SHARES $SharesString /CREDENTIALNAME "Optional Credential Name"
Enter-NetworkShare -Shares "\\hostname\c$","hostname2"
Requirements
- 1Password CLI must be installed and configured
- Replace "Default 1Password Credential Name Here" with the default credential name to use
This is my first time sharing anything so I hope I got the format right.
I thought about splitting this out into separate commands for re-usability, but that would make sharing harder.
ConnectToNetworkShares_1.0.0.ouc (12.5 KB)
