Hi!
I would like it, if the context-menu in the lister would behave the following way:
If there are several menu entries with the same mnemonic (underscored letter),
pressing the mnemonic key should cycle through the different menu entries with the respective mnemonic.
This behavior is implemented e.g. in Windows-Explorer.
In contrast, DOpus triggers the first menu-entry with the respective mnemonic.
