But Unlocker (an app for unlocking locked files and folders) does not show up in the context menu (it used to, but that was probably about a year ago).
What might have happened that made this app not show up in the context menu, and how do I get it back?
That's what I suspected. When Leo mentioned his 64-bit "success", I remembered my own change from 32 to 64, and figured that it was the reason. And it was. It now works great.
[quote="leo"]That worked for me, at last with the 64-bit Unlocker.
Does the menu item appear if you hold shift and right-click? What about in Explorer?
[/quote]
As you know from my response to Jon above, after uninstalling the 32-bit version of Unlocker, and installing the 64-bit version, Unlocker now show up in the context menu.
Thank you, Jon. And do you know when I will have even more fun – when I eventually get to Australia; I have been no further east than Israel, and no further south of Tangier in Morocco. (I believe that Tangier used to be an independent political entity of some kind, but no more.)
I've been to Brazil and Argentina, Canada and the USA (where I now live) and most of Europe when I was a radio operator in the Swedish Merchant Marine.
