A few items in the context menu are not working in Directory Opus, but they work fine in Explorer, and OneCommander. Items like "Edit with Kate", "Open with Sublime Text", and "Mediainfo". I tried restarting, and re-installing Dopus. When I click on them, I get nothing, not even an error message. Somebody please help me.
Can you launch the same tools from Opus via other methods (e.g. double-click their exes)? If not, antivirus might be blocking Opus from launching them.
Which versions of Opus, Windows and the tools are you using? We can try reproducing it with the same ones.
Launching the programs from Opus works fine. I tried both sublime and Kate and they both opened like normal. Also, right-click > open with > Sublime text/Kate works fine too. It's the "open with Sublime text/Kate" entry that doesn't work.
I'm using Opus 12.28 on Windows 10 (with the latest updates)
Sublime Text Build 4094, Kate 21.12.3, and MediaInfo v22.09
12.28 is half a year old, so please try with the current version first.
