I would like to change the vertical spacing - the spacing between lines - in context menus.
I know that the spacing of DO right-click menus is dependent upon the use of separators and the display of icons with the items. Explorer context menus have the same spacing as DOpus, with separators having the same effect, but their spacing is NOT dependent upon the display of icons. The Explorer icons are slightly smaller than the default DOpus icons but if an applications icon (from an .EXE or .DLL) is used in DOpus, it displays smaller; just as it does in Explorer. If a DOpus file-type context menu has only Explorer icons in it -- or no icons -- the DOpus menu will be shorter -- the same length as the Explorer menu. As a side note, DOpus file-type menu icons are never displayed in Explorer menus, even if an application's icon is used in the DOpus menu.
My questions: Can the DOpus context menu icon size be configured? I'm assuming if the icons were smaller, then the DOpus menus would be the same size as Explorer.
Or is there some other config parameter that can be adjusted? Of is there another DOpus icon set with smaller default icons?
