Copy a file and rename using Regex?
Hi
I want to be able to copy a file and append some text to the new file's name using Regex, how would I go about this?
Essentially I want to copy say:
And have the copy be called:
Any help would be appreciated!
Regards
Matt
Maybe instead you want to use the internal Copy command with wildcards, such as:
Copy DUPLICATE PATTERN . AS _thumbnail.
Thanks! That works well enough for what I want!
