Copy a path strukur (without file contents)
This time more a hint than a question,
as "PathDup 1.05 by Porcupine" is good for not to much and I initiately came to DOP looking for a tool which helps copying path structures, I finally found
hangvogel.hypermart.net/onlydircopy/
witch does what apparently nobody needs :slight_smile:
The best is, that it works with DOP an MS within the context menu!
Unfortunately it is shareware:-(
solong
Welcome aboard Andreas,
[quote] I finally found
The best is, that it works with DOP an MS within the context menu![/quote]
Thanks Andreas !
I've been playing with it some, but so far I can only copy the entire recursive structure below the selection point.
It could be useful, and noone has yet posted a program to the Resource Centre that does this 'simple' task.
PathDup was written for a different reason.
PathDup recognizes that there is logic in using arbitrary segments of Directory Structures .
This logic seemed to me as best exclusive of recursion.
"You can fool all the people some of the time,
and some of the people all the time,
but you cannot fool all the people all the time."
-- Abraham Lincoln
:opusicon: porcupine
Thanks porcupine
Ok, I obviously don't know what I could use this for, but propably need it :slight_smile:
Sorry, for undervalue it!
solong
Andreas
