I'd rather make vertical lines with things the border element or a colored div. Easier to change if needed. Now that I think of it, I rarely use the IMG tag for anything but actual photos.
It probably isn't quicker these days, where computers are so fast they can update a page's layout almost instantly, but it's definitely still nicer. If you don't specify an image's size then the browser uses small placeholders for each image and the page jumps around as things load and the real image sizes become know. Specifying the size means the browser will reserve that space and fill the image in when it's loaded without having to move anything around.
For things like background images, which don't affect layout, I don't think there is any benefit to specifying a size (if you even can specify the size of such things). I'm just talking about IMG tags.
[quote="Zippo"]@John,
My HTML has never passed ANY validator ![/quote]
I guess this is nothing you should be proud of. Neither is your code valid nor is it semantic (which is a prerequisite for accessible sites).
Greetings,
Jan
Ahhh yes, but it does work .
It also puts the top of the vertical line in the proper place.
How can we make this better ?
Something similar to this was discussed long ago in another forum.
It is still being used in Essen, Deutschland.
See DigicamFotos.de .
nor is it semantic
I do not know what you mean by "semantic". ![]()
Gruß,
Zippo
[quote="Zippo"]Ahhh yes, but it does work .
How can we make this better ?[/quote]
Try this one:
[code]
No Tables #imageContainer { float: right; padding: 5px 7px; border-left: 2px solid #404040; text-align: center; margin: 0; } #imageContainer dd { margin: 5px 0 0 0; }- Caption
Insert Text Here
[/code] It should look quite similar to your piece of code (didn't test it, though), but it's valid and semantic. The CSS goes to an external stylesheet. Then the code is [b]much[/b] more compact than yours is, too...I do not know what you mean by "semantic".
I guess there's no need to argue any more then... ![]()
@admins: Sorry for having been off topic, I just had to answer. Maybe you could make a new thread out of this discussion.
Greetings,
Jan
Thankyou Jan,
I tried your code.
I worked for more than an hour and I must admit you have won.
Your code solves the problems of this better.
I thank you for a very valuable lesson.
Greetings Enigma,
David
Edit Note:
While thinking about and working with Enigma's code,
I remembered why I used an image tag to make that vertical line.
The original thumbnails were 160 x 120 , but I wanted them displayed at 120 x 90.
I didn't want to resize them as I used the same thumbnails on other pages at 160 x 120.
The answer was to use the image tag to specify the smaller size.
Also using the image tag for the vertical line size was meant to remind me
of the connection.
I didn't think of "winning" or "losing", but I'm pleased that you gave it a try. ![]()
Greetings,
Jan
ALL Metadata
Retrieves all metadata of IMAGES, AUDIO, and VIDEO
Color, Dimensions, Resolution, Audio bitrate, Audio Code, Duration, Sample rate. Frame rate
New Button >>> Script Function >>> VBScript
Directory opus: 12 and above
Copy📋 > Image Metadata >
Both single and multiple
Example:
Filename: 01. LP.jpg
Color model: YCbCr
Dimensions: 1133 x 1700 x 24
Physical size: 15.7"" x 23.6""
Resolution: 72 dpi dpi x 72 dpi dpi
Filename: 02. LR.jpg
Color model: YCbCr
Dimensions: 901 x 1200 x 24
Physical size: 9.4"" x 12.5""
Resolution: 96 dpi dpi x 96 dpi dpi
Filename: 03. AD.jpg
Color model: YCbCr
Dimensions: 1376 x 1800 x 24
Physical size: 14.3"" x 18.8""
i!!!The same applies to Audio and Video.!!!
@script vbscript
Option Explicit
' OutputMode: "perfile" veya "grouped"
Const OutputMode = "perfile" ' <-- "perfile" ya da "grouped"
' Helper: temiz string
Function SafeStr(v)
On Error Resume Next
If IsEmpty(v) Then
SafeStr = ""
Else
SafeStr = CStr(v)
End If
If Err.Number <> 0 Then Err.Clear
On Error GoTo 0
End Function
' Meta verileri al (her dosya için)
Function GetImageMeta(item)
Dim meta, color, w, h, d, px, py, rx, ry, phys, res, out
color = "": w = "": h = "": d = "": px = "": py = "": rx = "": ry = ""
out = ""
Set meta = item.metadata
If Not meta Is Nothing Then
color = SafeStr(meta.image.colormodel)
If color = "" Then Err.Clear
w = SafeStr(meta.image.picwidth)
If w = "" Then w = SafeStr(meta.image.width)
h = SafeStr(meta.image.picheight)
If h = "" Then h = SafeStr(meta.image.height)
d = SafeStr(meta.image_text.picdepth)
If d = "" Then d = SafeStr(meta.image.picdepth)
If InStr(d, " ") > 0 Then d = Split(d, " ")(0)
px = SafeStr(meta.image.picphysx)
py = SafeStr(meta.image.picphysy)
If (px = "" Or py = "") Then
phys = SafeStr(meta.image_text.physicalsize)
If phys <> "" Then
phys = Replace(phys, Chr(34), "")
If InStr(phys, "x") > 0 Then
Dim pparts
pparts = Split(phys, "x")
px = Trim(pparts(0))
py = Trim(pparts(1))
End If
End If
End If
rx = SafeStr(meta.image.picresx)
ry = SafeStr(meta.image.picresy)
If (rx = "" Or ry = "") Then
res = SafeStr(meta.image_text.resolution)
If res <> "" Then
res = Replace(res, " dpi", "")
If InStr(res, "x") > 0 Then
Dim rparts
rparts = Split(res, "x")
rx = Trim(rparts(0))
ry = Trim(rparts(1))
Else
rx = Trim(res)
End If
End If
End If
End If
On Error GoTo 0
' Döndürülecek dizi benzeri string (pipe ile ayırıyorum, sonrasında split ile kullanılır)
GetImageMeta = color & "|" & w & "|" & h & "|" & d & "|" & px & "|" & py & "|" & rx & "|" & ry
End Function
Dim sel, item, count, i
Set sel = clickData.func.sourcetab.selected_files
If sel.count = 0 Then Exit Function
count = sel.count
If LCase(OutputMode) = "perfile" Then
Dim result
result = ""
For Each item In sel
Dim metaStr, parts
metaStr = GetImageMeta(item)
parts = Split(metaStr, "|")
Dim color, w, h, d, px, py, rx, ry
color = parts(0): w = parts(1): h = parts(2): d = parts(3)
px = parts(4): py = parts(5): rx = parts(6): ry = parts(7)
If color <> "" Or (w <> "" And h <> "") Or (px <> "" And py <> "") Or rx <> "" Then
result = result & "Filename: " & item.name & vbCrLf
If color <> "" Then result = result & "Color model: " & color & vbCrLf
If w <> "" And h <> "" Then
If d <> "" Then
result = result & "Dimensions: " & w & " x " & h & " x " & d & vbCrLf
Else
result = result & "Dimensions: " & w & " x " & h & vbCrLf
End If
End If
If px <> "" And py <> "" Then result = result & "Physical size: " & px & Chr(34) & " x " & py & Chr(34) & vbCrLf
If rx <> "" Or ry <> "" Then
If rx <> "" And ry <> "" Then
result = result & "Resolution: " & rx & " dpi x " & ry & " dpi" & vbCrLf
ElseIf rx <> "" Then
result = result & "Resolution: " & rx & " dpi" & vbCrLf
End If
End If
result = result & vbCrLf
End If
Next
If result <> "" Then DOpus.SetClip result
ElseIf LCase(OutputMode) = "grouped" Then
' Gruplanmış çıktı: her alan altında dosya: değer
Dim outColor, outDim, outPhys, outRes
outColor = "Color model:" & vbCrLf
outDim = "Dimensions:" & vbCrLf
outPhys = "Physical size:" & vbCrLf
outRes = "Resolution:" & vbCrLf
Dim metaStr2, p2
metaStr2 = GetImageMeta(item)
p2 = Split(metaStr2, "|")
Dim c2, ww, hh, dd, pxx, pyy, rxx, ryy
c2 = p2(0): ww = p2(1): hh = p2(2): dd = p2(3)
pxx = p2(4): pyy = p2(5): rxx = p2(6): ryy = p2(7)
If c2 <> "" Then outColor = outColor & " " & item.name & ": " & c2 & vbCrLf
If ww <> "" And hh <> "" Then
If dd <> "" Then
outDim = outDim & " " & item.name & ": " & ww & " x " & hh & " x " & dd & vbCrLf
Else
outDim = outDim & " " & item.name & ": " & ww & " x " & hh & vbCrLf
End If
End If
If pxx <> "" And pyy <> "" Then outPhys = outPhys & " " & item.name & ": " & pxx & Chr(34) & " x " & pyy & Chr(34) & vbCrLf
If rxx <> "" Or ryy <> "" Then
If rxx <> "" And ryy <> "" Then
outRes = outRes & " " & item.name & ": " & rxx & " dpi x " & ryy & " dpi" & vbCrLf
ElseIf rxx <> "" Then
outRes = outRes & " " & item.name & ": " & rxx & " dpi" & vbCrLf
End If
End If
Next
Dim finalOut
finalOut = ""
If Len(Trim(Replace(outColor, "Color model:", ""))) > 0 Then finalOut = finalOut & outColor & vbCrLf
If Len(Trim(Replace(outDim, "Dimensions:", ""))) > 0 Then finalOut = finalOut & outDim & vbCrLf
If Len(Trim(Replace(outPhys, "Physical size:", ""))) > 0 Then finalOut = finalOut & outPhys & vbCrLf
If Len(Trim(Replace(outRes, "Resolution:", ""))) > 0 Then finalOut = finalOut & outRes & vbCrLf
If finalOut <> "" Then DOpus.SetClip finalOut
End If
End Function
Copy📋 > Audio Metadata >
@script vbscript
Option Explicit
' Helper: güvenli string dönüşü
Function SafeStr(v)
If IsEmpty(v) Or IsNull(v) Then
SafeStr = ""
Else
SafeStr = CStr(v)
End If
On Error GoTo 0
End Function
' Helper: saniyeyi HH:MM:SS veya MM:SS formatına çevir
Function FormatDuration(secs)
Dim hh, mm, ss, sRem
If Not IsNumeric(secs) Then
FormatDuration = ""
Exit Function
End If
secs = CLng(secs)
hh = secs \ 3600
sRem = secs Mod 3600
mm = sRem \ 60
ss = sRem Mod 60
If hh > 0 Then
FormatDuration = Right("0" & CStr(hh),2) & ":" & Right("0" & CStr(mm),2) & ":" & Right("0" & CStr(ss),2)
Else
FormatDuration = Right("0" & CStr(mm),2) & ":" & Right("0" & CStr(ss),2)
End If
End Function
' Audio metadata için güvenli alma - birçok alternatif alan adı dener
Function GetAudioMeta(item)
Dim md, b, c, secs, txtDur, srate
b = "": c = "": secs = "": txtDur = "": srate = ""
Set md = item.metadata
If Not md Is Nothing Then
b = SafeStr(md.audio_text.mp3bitrate)
If b = "" Then b = SafeStr(md.audio_text.bitrate)
If b = "" Then b = SafeStr(md.audio.bitrate)
c = SafeStr(md.audio.audiocodec)
If c = "" Then c = SafeStr(md.audio_text.codec)
If c = "" Then c = SafeStr(md.audio.codec)
secs = SafeStr(md.audio.mp3songlength)
If secs = "" Then secs = SafeStr(md.audio.songlength)
If secs = "" Then secs = SafeStr(md.audio.length)
If secs = "" Then txtDur = SafeStr(md.audio_text.duration)
If txtDur = "" Then txtDur = SafeStr(md.audio_text.length)
If txtDur = "" Then txtDur = SafeStr(md.audio_text.songlength)
srate = SafeStr(md.audio_text.mp3samplerate)
If srate = "" Then srate = SafeStr(md.audio_text.samplerate)
If srate = "" Then srate = SafeStr(md.audio.audiosamplerate)
End If
On Error GoTo 0
Dim durOut
durOut = ""
If IsNumeric(secs) And secs <> "" Then
durOut = FormatDuration(CLng(secs))
ElseIf txtDur <> "" Then
If InStr(txtDur, ":") > 0 Then
Dim parts, pCount, totalSecs
parts = Split(txtDur, ":")
pCount = UBound(parts) - LBound(parts) + 1
totalSecs = 0
If pCount = 3 Then
totalSecs = CLng(Trim(parts(0))) * 3600 + CLng(Trim(parts(1))) * 60 + CLng(Trim(parts(2)))
ElseIf pCount = 2 Then
totalSecs = CLng(Trim(parts(0))) * 60 + CLng(Trim(parts(1)))
End If
If totalSecs > 0 Then
durOut = FormatDuration(totalSecs)
Else
durOut = txtDur
End If
Else
durOut = txtDur
End If
End If
GetAudioMeta = b & "|" & c & "|" & durOut & "|" & srate
End Function
' Main
Dim sel, item, result, metaStr, parts
result = ""
metaStr = GetAudioMeta(item)
Dim bitR, codecT, durT, sT
bitR = parts(0): codecT = parts(1): durT = parts(2): sT = parts(3)
If bitR = "" And codecT = "" And durT = "" And sT = "" Then
' skip
Else
If bitR <> "" Then result = result & "Audio bit rate: " & bitR & vbCrLf
If codecT <> "" Then result = result & "Audio codec: " & codecT & vbCrLf
If durT <> "" Then result = result & "Duration: " & durT & vbCrLf
If sT <> "" Then result = result & "Sample rate: " & sT & vbCrLf
End If
Next
Else
DOpus.Output "Hiçbir ses metadata'sı okunamadı."
End If
End Function
Copy📋 > Video Metadata >
@script vbscript
Option Explicit
' Çıktı modu: "perfile" veya "grouped"
Const OutputMode = "perfile" ' <-- "perfile" veya "grouped"
' Güvenli string dönüşü
Function SafeStr(v)
SafeStr = ""
Else
SafeStr = CStr(v)
End If
On Error GoTo 0
End Function
' Saniyeyi HH:MM:SS veya MM:SS formatına çevir
FormatDuration = ""
Exit Function
End If
secs = CLng(secs)
hh = secs \ 3600
mm = sRem \ 60
ss = sRem Mod 60
If hh > 0 Then
Else
End If
End Function
' Bir item (dosya) için video meta al, pipe ile ayrılmış string döndür
Function GetVideoMeta(item)
Dim md, dimsText, w, h, durNum, durText, fr, srate
dimsText = "": w = "": h = ""
durNum = "": durText = ""
fr = "": srate = ""
' Dimensions: çeşitli alanları dene
w = SafeStr(md.video.width)
If w = "" Then w = SafeStr(md.video.picwidth)
If w = "" Then w = SafeStr(md.video_text.width)
h = SafeStr(md.video.height)
If h = "" Then h = SafeStr(md.video.picheight)
If h = "" Then h = SafeStr(md.video_text.height)
dimsText = w & " x " & h
Else
dimsText = SafeStr(md.video_text.dimensions)
If dimsText = "" Then
' bazen tek alanı "3840 x 2160" olarak verir
dimsText = SafeStr(md.video.dimensions)
End If
End If
' Duration: numeric tercih, yoksa text alanları
durNum = SafeStr(md.video.duration)
If durNum = "" Then durNum = SafeStr(md.video.videolength)
If durNum = "" Then durText = SafeStr(md.video_text.duration)
If durText = "" Then durText = SafeStr(md.video_text.videolength)
' Frame rate
fr = SafeStr(md.video.framerate)
If fr = "" Then fr = SafeStr(md.video_text.framerate)
If fr = "" Then fr = SafeStr(md.video.fps)
' Sample rate (audio inside video)
End If
On Error GoTo 0
' Normalize duration: numeric -> format; else parse mm:ss/h:mm:ss
Dim durOut
durOut = ""
If IsNumeric(durNum) And durNum <> "" Then
durOut = FormatDuration(CLng(durNum))
ElseIf durText <> "" Then
If InStr(durText, ":") > 0 Then
parts = Split(durText, ":")
totalSecs = 0
If pCount = 3 Then
End If
If totalSecs > 0 Then durOut = FormatDuration(totalSecs) Else durOut = durText
Else
durOut = durText
End If
End If
GetVideoMeta = dimsText & "|" & durOut & "|" & fr & "|" & srate
End Function
' Main
Dim sel, item
Dim result, metaStr, parts
result = ""
metaStr = GetVideoMeta(item)
Dim dimsT, durT, frT, sT
dimsT = parts(0): durT = parts(1): frT = parts(2): sT = parts(3)
If dimsT = "" And durT = "" And frT = "" And sT = "" Then
' skip empty
Else
If dimsT <> "" Then result = result & "Dimensions: " & dimsT & vbCrLf
If frT <> "" Then result = result & "Frame rate: " & frT & vbCrLf
End If
Next
Dim outDims, outDur, outFr, outS, metaStr2, p2
outDims = "Dimensions:" & vbCrLf
outDur = "Duration:" & vbCrLf
outFr = "Frame rate:" & vbCrLf
outS = "Sample rate:" & vbCrLf
metaStr2 = GetVideoMeta(item)
Dim d2, du2, f2, s2
d2 = p2(0): du2 = p2(1): f2 = p2(2): s2 = p2(3)
If d2 <> "" Then outDims = outDims & " " & item.name & ": " & d2 & vbCrLf
If du2 <> "" Then outDur = outDur & " " & item.name & ": " & du2 & vbCrLf
If f2 <> "" Then outFr = outFr & " " & item.name & ": " & f2 & vbCrLf
If s2 <> "" Then outS = outS & " " & item.name & ": " & s2 & vbCrLf
Next
Dim finalOut
finalOut = ""
If Len(Trim(Replace(outDims, "Dimensions:", ""))) > 0 Then finalOut = finalOut & outDims & vbCrLf
If Len(Trim(Replace(outDur, "Duration:", ""))) > 0 Then finalOut = finalOut & outDur & vbCrLf
If Len(Trim(Replace(outFr, "Frame rate:", ""))) > 0 Then finalOut = finalOut & outFr & vbCrLf
If Len(Trim(Replace(outS, "Sample rate:", ""))) > 0 Then finalOut = finalOut & outS & vbCrLf
End If
End Function
I don't remember this thread at all .
A few different ways to do this have been added in the almost 20 years since this thread. ![]()
