Copy dialog brings Dopus main window to the front when selected
When the copy/move dialog is obscured behind some window, and I click on it to bring it to the front, it brings the main DOpus windows to the front also. This didn't happen in DOpus 12. Only the copy dialog came to the front. Is there a way?
I'm running the newest 13.7.
It's kind of by design, in that in Opus 13 we removed the older "hacky" method we were using to keep the progress dialog on top of the Lister that launched it. It's now a standard "owned" window, which means it always appears on top of the Lister. One side effect is that the Lister always comes to the front when it does.
We've improved this in 13.7.5 - the first time you minimize the progress dialog to the taskbar, the link between it and its parent Lister is broken, so when you restore the dialog it'll no longer bring the Lister to the front with it.
I see.
Since the minimize thing works, couldn't you make DOpus do a swift minimize / restore when the dialog opens the first time? Or will it look glitchy?
