Copy from lastmodifieddate not working
While trying to sync the date and time info in some JPGs I noticed that these commands work as expected:
SetAttr META lastmodifieddate:createdate datetaken:createdate datedigitized:createdate
SetAttr META createdate:datetaken lastmodifieddate:datetaken datedigitized:datetaken
SetAttr META createdate:datedigitized lastmodifieddate:datedigitized datetaken:datedigitized
but this one doesn't:
SetAttr META createdate:lastmodifieddate datetaken:lastmodifieddate datedigitized:lastmodifieddate
Is this a bug or am I doing anything wrong?
It should be createdate:modifydate etc. rather than createdate:lastmodifieddate etc.
But it's an easy mistake to make, since the keywords after the : are the same as the column names before the : in the other cases, so we'll make a code change to make both work.
Thanks :slight_smile:
The "last" in "lastmodifieddate" sounded a bit awkward anyway.
While you are at it: wouldn't "date" + past tense be the most consistent way of naming the columns and keywords?
