When I drag&drop mp3 file to metadata panel, we have 3 choices...
1st item: Year is not copied
2nd item: Year, BMP, Initial key, release date and subtitle are not copied
3rd item: Year and Copyright are not copied
Normal ?
Normal ?
Something planned to solved this ?
This will be fixed in the next update.
No really solved for me.
Year is never copy and Genre only if it is predefined (custom Genre never copy).
Year copies for me.
You didn't say anything about Genre in your original report.
It’s strange… My mp3 test have 2014 and year is not copy. If I change it to 2013, year is copy.
Yes, maybe my first test file have standard Genre string…
I still can't reproduce the year issue. If you want to upload an example file that exhibits the problem I'll give it a try.
You can find here, samples and video capture.
Thanks, I can reproduce it now and it will be fixed in the next update.
It was quite specific actually - for it to fail, the "destination" file had to have no year set at all, and the "source" file had to be set to the current year (i.e. 2014).
