Have done a bit more investigation into this bug.
If a detached script dialog is already showing and a copy/move operation initiated on the same drive or internal drive the copy/move dialog does not show until the script dialog is closed.
Steps to reproduce:
- show a script detatched dialog, here is a basic one (called with
Simple_dialog
) Simple dialog.opusscriptinstall (1.3 KB) - initiate a copy/move operation internally, large enough to show the copy/move dialog for 30 seconds or so.
Not sure if it's the type of drives causing the bug,
my internal ones are PCIe M.2 SSDs,
the bug does not happen with external HDDs.
