Micky
September 30, 2024, 8:32am
1
Currently moving a lots of files from one network share to another and noticed that the performance graphs are missing:
Do I have to enable an option for this to be shown? OTH, I got the graph while copying/moving some other files before, so it seems not a global issue here.
Leo
September 30, 2024, 11:26am
2
Looks like they can’t be calculated for some reason.
The size of the file being copied isn’t displayed either, which is unusual.
Anything unusual about the drive?
Micky
September 30, 2024, 11:54am
3
The size is shown and changes for each copied/moved file, just watched the progress:
Edit: It's not the same size information as in screenshot below, just noticed.
I can not see anything unusual here. I'm connected with my tablet to the company, using VPN, and the drive letter W: is mapped to a network share.
Strange enough, when doing another copy, I get the graph:
The source again is a mapped network share and the target is the same drive letter as above, different subfolder, though.
Leo
September 30, 2024, 11:57am
4
Micky:
The size is shown
That’s the amount copied so far, not the total size (which normally appears in the blank space to the right of that).
Micky
September 30, 2024, 12:00pm
5
Maybe I've found the difference which may cause the graph disappearing?
In my initial posting, I'm moving files from a grouped lister (eval groups) to a destination folder, although grouped. The graph is missing!
When copying the same files from the same (grouped) source as above to another location, not grouped , I get the graph:
Edit : to be precise: It's the grouped source which causes the graph to not appear, not the destination.
Leo
September 30, 2024, 1:56pm
6
A screenshot showing how the lister is grouped and what's selected before copying might help understand what's happening. As far as I can think, grouping shouldn't affect the graph.
Micky
September 30, 2024, 2:49pm
7
Here you go. Currently two groups are used/visible and I selected the files in the second visible group, using the header of the group:
Then I pressed the move button on my toolbar without any modifier:
@keydown:none
Copy MOVE
@keydown:shift
Copy MOVE AS
The target folder has the same grouping scheme activated as the source. The graph is missing during the move process:
Which means now:
Source
Destination
Graph
Grouped
Grouped
None
Ungrouped
Grouped
Yes
Grouped
Ungrouped
Yes
I'm using this evaluator group
if ((value > Now()) || UCase(ext) != "HTML" ) { return };
// date calculations for performance increase
diffMonths = DateDiff("m", Now(), value);
// diffDays = DateDiff("d", Now(), value);
diffDays = Age(value);
currentWeek = (Now() as "D#yyyyww" as int);
valueWeek = (value as "D#yyyyww" as int);
collapse = true;
if (diffDays == 0) { group = "Today"; order = 1; } //today
elseif(diffDays == -1) { group = "Yesterday"; order = 3; } //yesterday
elseif(currentWeek == valueWeek ) { group = "This week"; order = 5; } //this week
elseif(currentWeek - valueWeek == 1 ) { group = "Last week"; order = 7; } //last week
elseif(diffMonths == 0 ) { group = "This month"; order = 9; } //this month
elseif(diffMonths == -1 ) { group = "Last month"; order = 11; } //last month
elseif(DateDiff("yyyy", Now(), value) == -1 ) { group = "Last year"; order = 999; } //last year
else { group = Format("%1 - %2", value as "D#yyyy", value as "D#MMMM");
// sort to the bottom
order = 99 + ((Now() as "D#yyyy" as int) - (value as "D#yyyy" as int) as int + (value as "D#MM") as int); };
if ( InStr( name, "_ERROR" ) > 0)
{ collapse = ( order == 1 ) ? false : true;
group += " (with error)";
order += 1;
// Output("Name: " + name + " Group:" + group + " Order:" + order + " Collapse:" + collapse );
return [ name = group; order = order; collapse = collapse ];
