Noticed that when displaying files* only and when copying a file (ctrl-c/v) the word (Copy) is not added to the filename, as it normally is.
Found out that this is because the file is stored in the parent folder, rather than in the same folder, i.e.
in the below example, for instance, the Paragon manual (source) is stored in
x:\pdf\software\paragon - whereas the copy is then stored in x:\pdf\software.
Maybe this is correct, I don't know.
It is a minor thing only.
*Set FLATVIEW=Toggle,MixedNoFolders
p.s. I tried to submit this thread using the following title:
Copy file in "FLATVIEW=Toggle,MixedNoFolders'-mode copy stored elsewhere
but that was rejected 'Title seems unclear, is it a complete sentence?' with only the [OK] button.
