Copy Rename on same folder, recursively
Hello
What I am trying to achieve is to select a folder,
and copy every file matching a pattern e.g. ".zip"
to a file named after another pattern e.g. "
.zip.bak" on the same folder as the original file.
Then recursively do that for each subdirectory of the original folder.
Is there a way to achieve this with Directory Opus.
One alternative (which I still don't know how to go about) could be that I search for all files "*.zip" on a folder
and then select all files on the results collection and copy - rename them to the same folder. But Duplicate button does not
work on a collection.
Any help would be greatly appreciated
Create a button (or hotkey, etc.) which runs this command:
@nofilenamequoting Copy "{filepath$}" TO "{filepath$|..}" as "{file$}.bak"
(If you need help creating the button, just ask.)
You can then use that button on your Find Results. i.e. Do a search for *.zip, select all the results, then click the button to create .bak copies of everything that's selected.
Thanks a lot Leo
