Copy string to clipboard
Hi again,
Is there a way to copy a specific string to clipboard using a raw command?
Reason I'm asking is this:
I'm using Dropbox, and sync files are kept in a regular folder. If I was to copy a public direct url to a file, I could use to right click context menu.
That will copy to my clipboard a URL that look something like this:
http://dl.getdropbox.com/u/666666/my_file.txt
Where 666666 is my user id. and my_file.txt is the selected file.
I was wondering if there's a way to bypass the context menu and create a command that will build this URL and copy it to my clipboard.
Any suggestions?
Thanks in advance.
Now playing: Death Cab For Cutie - Bixby Canyon Bridge
Well, I guess it doesn't get much more simple than that:
@nofilenamequoting
Clipboard SET http://dl.getdropbox.com/u/6666/{file}
Thanks, I guess I need to spend more time playing around with arguments before posting :slight_smile:
Now playing: Death Cab For Cutie - Long Division
Now, just in case someone is interested, I created a button that copies the selected file and the public URL to the clipboard.
This is the fastest and easiest way I found to share files [pretty much like ImageShack, but for all types of files].
@nodeselect
@nofilenamequoting
Go "C:\My Dropbox\Public" OPENINDEST
COPY
Clipboard SET http://dl.getdropbox.com/u/666666/{file}
Where "C:\My Dropbox\Public" is the dropbox location on the local computer. And 666666 is dropbox user id.
If anybody has any other suggestions or improvements, please feel free.
Now playing: Death Cab for Cutie - Marching Bands Of Manhattan
If you only want to copy the file then you can simplify it to this:
@nodeselect @nofilenamequoting COPY TO "C:\My Dropbox\Public" Clipboard SET http://dl.getdropbox.com/u/666666/{file}
