Copy UNATTENDED=yes WHENEXISTS=rename [error dialog popup appears]
I created a new button with this command + arguments [Copy UNATTENDED=yes WHENEXISTS=rename]. Once I click the button, the error dialog appears waiting for action. If I click retry, then the file is copied / renamed. I was expecting the command to work with my action.
errordialog
hmm.
this afternoon i make a new Context Menu Item on the Programs Group with this command
copy MAKELINK TO /start\programs WHENEXISTS=replace
it did not replace, it renamed (2).lnk
possibly not related, but seems it could be.
Thanks for reporting this! We'll make that combination work in the next beta.
Edit: Fixed in Directory Opus 13.7.6 (Beta)
