Hi there...
I was going to revive my old thread about ZIP, but i think a new one should be better.
Well, here i go, i changed my button to the following:
Copy ARCHIVE=keepfolder CREATEFOLDER="{s|nopath|noterm}.xpi" HERE WHENEXISTS=merge,replace FORCE COPYATTR=no [i]COPYDIRTIMES=no [b]COPYFILETIMES=no[/b] COPYOWNER=no COPYPROPERTIES=no COPYDESC=no COPYSECURITY=no [/i]
However, COPYFILETIMES=no seems to do nothing, ie. all three datestamps are being added:
(btw, im aware most of these args may does nothing on ZIPs, but i'm just trying to make them as small as possible)
Path = bootstrap.js
Folder = -
Size = 19797
Packed Size = 6293
Modified = 2013-03-14 08:20:02
Created = 2012-09-10 16:24:14
Accessed = 2012-09-10 16:24:14
Attributes = ....A
I did read on a post by Igor P. that he thinks it is "illegal" for ZIP archives to not have the modtime value, so i think that arg should at least get rid of accessed and created datestamps. But, it is illegal really? ie, what would happen if that contains just 0s? I tried it... for the last couple of days i have been trying to find a (erm..) human-readable ZIP spec, and found this from a ZIP creator in PHP:
$fr = "\x50\x4b\x03\x04";
$fr .= "\x14\x00"; // version needed to extract
$fr .= "\x00\x00"; // general purpose bit flag
$fr .= "\x08\x00"; // compression method
$fr .= "\x00\x00\x00\x00"; // last mod time and date
// now add to central directory record
$cdrec = "\x50\x4b\x01\x02";
$cdrec .="\x00\x00"; // version made by
$cdrec .="\x14\x00"; // version needed to extract
$cdrec .="\x00\x00"; // general purpose bit flag
$cdrec .="\x08\x00"; // compression method
$cdrec .="\x00\x00\x00\x00"; // last mod time & date
So... i ran a hex editor and edited bytes 10-14 and the corresponding ones for the cd part, Zeroing them. Can you guess the result? it caused nothing.. I mean, after zeroing 8 bytes the only file within the archive still had the same modtime and was being properly readable. Huh?
Then, i started randomly zeroing other parts after the 'ushort' indicating the filename's length on the central-dir record and then noticed funny modtimes such as 1882 or 2056, heh.
Well, at this point i can see this might became off-topic from what it was/looked initially, but it is to understanding what i'm trying to achieve... a smaller ZIP archive with either removed or fake modtime. Why, you ask? well... the md5/sha1/xyz checksum will not change unnecessarily for example...
Additionally, i would love the ability to change the file permissions from ZIP files as well (without the need to change the original files and revert them once packed).
So... TL;DR;
COPYFILETIMES=no should at least not set accessed/created.
It'll be great if SETATTR could work recursively over selected ZIP archives.
What do you think?
Cheers.
