If I copy a symlink that points to a folder, DOpus does not count files inside this folder.
Symlink was created with DOpus.
I initiate the copy by drag&drop.
I copy the whole folder, ie. I drag&drop the symlink itself to another disk.
DOpus shows that it has copied 0/1 files, although the folder that is being copied contains ~200 files.
Files are copied correctly, the only thing I'm asking for is to make progress info more useful.
Is Preferences / File Operations / Progress Indicators / Count files in folders before copying for set the same as before? What's it set to at the moment?
