dammit
i just had the path wrong, i had to change
DOpusRTPath = "C:\Program Files\Directory Opus\dopusrt.exe"
to
DOpusRTPath = "C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe"
now it works
i guess i really am a monkey
dammit
to
now it works
it's written few posts before!
[quote="der_affe"]
-is there a way to create a folder named from the parent folder?
help!
much thanks! tussen takk! vielen dank
[/quote]
I figured out how to create a folder named from parent folder- anyone who wants to try it, paste this into an advanced button:
CreateFolder "New Folder"
Rename "New Folder" TO="{parent}.{ext}" FILEINFO
does it work for anyone?
You need to understand what you do...
Your 1st lign create folder "New folder" in current folder, then your 2nd try to rename folder in your new folder named "New Folder". But "New folder" doesn't exist.
Then {ext} is for extension. Folders have extensions ? So you don't need to use that. So...
CreateFolder "New folder" READAUTO=no
Rename "New folder" TO="{parent}" FILEINFO
READAUTO=no -> not enter new folder
But if you want to enter new folder...
Rename {sourcepath} TO="{parent}" FILEINFO
And for your PM message (Add codec to folder name), you want the codec name ?
AlbatorV, thanks for your time!
look i have a question, it relates back to this post you made Rename parent folder from selected file metadata
you wanted to rename the parent folder based on the audio tags. well, i want to just create a folder, based on audio tags...
i try this code:
Select *.mp3
@dirsonly
Rename FILEINFO TO "{mp3artist} - {mp3album} - Album Art"
but it's creating a folder that looks like this- it's as though it's trying to do it, but it can't get the tag information to name the folder with:
any thoughts are appreciated, getting this right would save me alot of time, as i have alot of audio to sort out.
maybe, Rename FILEINFO doesnt work for folders? if thats true, would there be a corresponding command for folders?
thanks!
FILEINFO works for folders but in your command you want to rename folder based on mp3 fileinfo.
Forders are not mp3, so it's not possible like that.
You need to use vbscript to catch mp3 infos and create folder with these infos.
i was afraid you would say that
looking at your script from the other post where you were trying to rename parent folder from audio tags, i noticed this was the important part (i think)
strCommand = """" & DOpusRTPath & """ /cmd Rename {filepath$|..|noterm} TO=""" & artist & " - " & album & " (" & annee & ")"""
maybe the /cmd Rename {filepath$|..|noterm} could be changed to create a folder, instead of renaming parent? i have no idea about scripting so im trying to be derivative, but to keep guessing could take me ages
help oh gurus!!
@nodeselect
Rename FILEINFO TO="{mp3artist}_{mp3album}_{mp3year}"
@script vbscript
Option Explicit
dim DOpusRTPath
Dim Shell
Set Shell = CreateObject("WScript.Shell")
Dim fFirst
fFirst = TRUE
Function Rename_GetNewName(strFileName, strFilePath, fIsFolder, strOldName, ByRef strNewName)
Dim strCommand
Dim artist
Dim strInfoArray
Dim album
Dim annee
strInfoArray = split(strNewName, "_")
strNewName = ""
If fFirst Then
fFirst = FALSE
artist = strInfoArray(0)
album = strInfoArray(1)
annee = strInfoArray(2)
strCommand = """" & DOpusRTPath & """ /cmd CreateFolder """ & artist & " - " & album & " - " & "Album Art" & ""
Shell.Run strCommand,0,false
End if
End Function
Perhaps you'll also like this variation:
Create Folder: "Artist - Album - (Year) (mp3 bitrate)
@nodeselect
Rename FILEINFO TO="{mp3artist}_{mp3album}_{mp3year}_{mp3bitrate}"
@script vbscript
Option Explicit
dim DOpusRTPath
Dim Shell
Dim fFirst
fFirst = TRUE
Dim strCommand
Dim artist
Dim strInfoArray
Dim album
Dim annee
Dim bitrate
strNewName = ""
If fFirst Then
fFirst = FALSE
bitrate = strInfoArray(3)
strCommand = """" & DOpusRTPath & """ /cmd CreateFolder """ & artist & " - " & album & " - " & "(" & annee & ") " & "(" & "mp3 " & bitrate & ")"""
End if
End Function
Astounding, it's working properly
things i used to have to type manually over and over again, i can now reproduce with one click!
thanks very much to all of you guys who have helped me! alot of work has gone into those scripts i know, and i appreciate everyone sharing their knowledge.
i made a button with the new operations:
and if i could, could i ask one last final question that relates somewhat to this?
all the files in the screenshot above that are not music files- the .jpg, .txt file etc. - how could i select them all and move them into the folder named "album art" with a button? the folder's name would be variable, but will always contain "album art"
i figure the command would be something like this:
Select *(.txt|.cue|.jpg|.log)
Copy MOVE HERE= "*Album Art"
i know the above isnt right, but its the way im thinking it would work, can anyone help out? this will finish up what im working on
again thanks to kundal & albatorV you guys have been a great help
@set dest={filepath}
Select NONE
Select *.(txt|cue|jpg|log)
Copy MOVE TO={$dest}
CreateFolder "Rip Logs"
Select "Rip Logs"
Select NONE
Select *.(txt|cue|log|m3u|md5)
anyway to set a relative folder path?
kundal, when you get some time could you pm me, i got one little problem with the script, unless you'd rather i posted it here?
thanks
How about shortening it to a one-liner:
Copy MOVE FILE *.(txt|cue|log|m3u|md5) CREATEFOLDER "Rip Logs" HERE
Side Note: sometimes, using 'Select' commands in multi-command buttons doesn't work as well as you'd expect... a "timing issue" sometimes perhaps. You'd probably never come across an issue with that given this particular use-case, but at any rate... this one-liner is just simpler and less to 'potentially' go wrong.
kundal, i'll go ahead and post it here-
i'm using this script you gave me to rename parent folder from tags:
strCommand = """" & DOpusRTPath & """ /cmd Rename {filepath$|..|noterm} TO= """ & artist & " - " & album & " - " & "(" & annee & ") " & "(" & "mp3 " & bitrate & ")"""
it works great, but i have one small problem with it: if the audio files arent mp3, if theyre flac for example, it still names the parent folder "mp3 ~592 kbps" is there a switch i could use instead, maybe %codec% or %extension%, so that filetype would always show properly?
thanks so much!!
@steje - thanks for your help as well, done and implemented
Post the full script if you need help... and not PM...
Question : do you understand how the script works ? Because display "mp3" or "flac", it's the same way.
ok-- i use this script to rename parent folder from tags:
@filesonly
Select *(.mp3|.flac|.ape|.ogg|.mpc)
Rename FILEINFO TO="{mp3artist}{mp3album}{mp3year}{mp3bitrate}"
@script vbscript
Option Explicit
dim DOpusRTPath
Dim Shell
Dim fFirst
fFirst = TRUE
Dim strCommand
Dim artist
Dim strInfoArray
Dim album
Dim annee
Dim bitrate
strInfoArray = split(strNewName, "")
strNewName = ""
If fFirst Then
fFirst = FALSE
End if
End Function
and when i use it, it always includes "mp3" in the name, regardless of what type the source audio files are-- see screen:
i was thinking there might be an %codec% or %extension% switch so that the folder names will properly reflect the filetypes
anyone, have thoughts? besides the idea that i have lost it...
@filesonly
Rename FILEINFO TO="{mp3artist}_{mp3album}_{mp3year}_{mp3bitrate}_{ext}"
@script vbscript
Option Explicit
Dim DOpusRTPath, Shell, fFirst
fFirst = TRUE
Dim strCommand, strInfoArray, artist, album, yyear, bitrate, extension
strNewName = ""
If fFirst Then
fFirst = FALSE
yyear = strInfoArray(2)
extension = strInfoArray(4)
strCommand = """" & DOpusRTPath & """ /cmd Rename {filepath$|..|noterm} TO=""" & artist & " - " & album & " - " & "(" & yyear & ") (" & extension & " " & bitrate & ")"""
Dopus.OutputString "Commande : " & strCommand
End if
End Function
@AlbatorV:
Your last one is not working correctly for me.
You should only select a single musicfile with this Button. Otherwise the Rename Window will come up (even if you add "@firstfileonly" to the code)
Rename FILEINFO TO="{ext}_{mp3artist}_{mp3album}_{mp3year}_{mp3bitrate}"
@script vbscript
Option Explicit
dim DOpusRTPath
Dim Shell
Dim fFirst
fFirst = TRUE
Dim strCommand
Dim artist
Dim strInfoArray
Dim album
Dim year
Dim bitrate
Dim extension
strNewName = ""
If fFirst Then
fFirst = FALSE
extension = strInfoArray(0)
artist = strInfoArray(1)
album = strInfoArray(2)
year = strInfoArray(3)
bitrate = strInfoArray(4)
strCommand = """" & DOpusRTPath & """ /cmd Rename {filepath$|..|noterm} TO= """ & artist & " - " & album & " - (" & year & ") (" & extension & " " & bitrate & ")"""
End if
End Function
