Hi am trying to make few buttons that would do the following:
1.A button that moves all files with a given extension say ""Jpeg" to the root folder and then delete the folder.Basically it copies all the files with any given extension,goes up a folder pastes the copied files and then deletes that folder from which files were copied.
2.A button that takes me up one level and deletes the last folder i visited.
Is there a way to provide the path of various levels of directories to a command for example the buttons described above....can they be configured with one level up,two level up....etc
